Ragazzi propongo questo sondaggio. Sono due auto fantastiche, nonchè le più veloci sulla pista di Top Gear (CCX: 1:17.6 - Zonda F: 1:18.4)
Koenigsegg CCX - Specifiche tecniche
Engine
Type: Koenigsegg V8 cast aluminium, 4 valves per cylinder, double overhead camshafts.
Displacement: 4.700 cm3
Compression: 8.2:1
Lubrication system: Dry sump with oil spray piston cooling.
Oil cooler.
Sequential, multipoint fuel injection. Twin Rotrex centrifugal superchargers with response system 1.2 bar boost pressure
Power output: 806 Bhp at 6.900 rpm
Maximum torque: 920 Nm (678ftlb) at 5.700 rpm.
Transmission
Specially developed 6-speed gearbox by Cima. Torque sensitive, limited slip differential.
Clutch: Dual plate, Ø 215 mm (8.46 inch)
Gear ratios: 3.545
1st gear: 2.875
2nd gear: 1.773
3rd gear: 1.267
4th gear: 1.000
5th gear: 0.833
6th gear: 0.711/0.733
Reverse gear: 3.000
Performance
Acceleration: 0-100 km/h (0-62 mph) 3.2 seconds
Top speed: 395+ km/h (245+ mph)
Standing Quartermile: 9.9 seconds, end speed 235 km/h (146 mph)
Braking distance: 31m (100-0 km/h)
Lateral G-force: 1.3 G
Fuel Consumption: Highway travel: 13 l / 100 km
Combined: 17 l / 100 km
Body
Two-door, two seater with removable hartop stowable under the front hood lid. Body made of pre-impregnated carbonfibre/ Kevlar and lightweight sandwhich reinforcements.
Dimensions
Total length: 4293 mm (169")
Total width: 1996 mm (78.6")
Total height: 1120 mm (44.1")
Ground clearance: 100 mm (3.9")
Fuel capacity: 70 litres (18.5 gallons US)
Luggage compartment: 120 litres (31.7 gallons US)
Dry weight: 1180 kg (2601 LBS)
Aerodynamics
Cd. 0.3 Frontal area 1.867 m2. Flat underside of chassis. Venturi tunnels at rear of chassis/ body.
Steering
Rack and pinion power assisted steering. 2.7 turns lock to lock. Turning circle: 11 metres Chassis
Semi monocoque made of pre-impregnated carbonfibre and honeycomb
Front and rear suspension: Double wishbones, adjustable Racing gas-hydraulic shock absorbers, pushrod operated. Anti-roll bar. Electronically adjustable ride height.
Front brakes: Ventilated discs Ø 362 mm, 32 mm wide. 6 piston light alloy callipers. Power assisted. Koenigsegg Advanced Control System.
Rear brakes: Ventilated discs Ø 362 mm, 32 mm wide. 6 piston light alloy callipers. Power assisted. Koenigsegg Advanced Control System.
Optional
380x34 mm ceramic discs with 8 piston callipers.
Wheels
Koenigsegg magnesium alloy wheels with centre locking. Optional: Carbon / Magnesium wheels Front: 19" x 9.5" Rear: 20" x 12.5"
Tyres
Michelin Pilot Sport 2
Undirectional with asymmetric tread pattern.
Front: 255/35-19" (Y)
Rear: 335/30-20" (Y)
Pagani Zonda F - Specifiche tecniche
Performance
0-60 mph 3.6 seconds.
Top Speed 345 km/h | 214.4 mph Similar top speeds
Engine
Engine Configuration V
Cylinders 12
Engine Mercedes-Benz AMG engine
Aspiration/Induction Normal
Displacement 7291.00 cc | 444.9 cu in. | 7.3 L.
Valves 48 valves.
4 valves per cylinder.
Horsepower 603.00 BHP (443.8 KW) @ 6150.00 RPM
Torque 561.00 Ft-Lbs (760.7 NM) @ 4000.00 RPM
HP to Weight Ratio 4.5 LB / HP
HP / Liter 82.6 BHP / Liter
Redline 7000
Standard Transmission
Gears 6
Transmission Manual
Dimensions
Seating Capacity 2
Doors 2
Exterior
Length 4435.001 mm | 174.6 in.
Width 2055.001 mm | 80.9 in.
Height 1141.001 mm | 44.9 in.
Wheelbase 2730.001 mm | 107.5 in.
Suspension
Suspension 4 independent wheels with double A-arm; pull rod helical springs and Öhlins adjustable shock absorbers; anti-roll bar; aluminium/magnesium alloy suspension arms.
Brakes
Front Brake Size 380.001 mm | 15 in.
Rear Brake Size 355.001 mm | 14 in.
Tires / Wheels
Tires Front : Michelin Pilot Sport 255/35/19
Rear : Michelin Pilot Sport
Wheels Front : 335/30/20
Rear : Forged aluminium/magnesium alloy APP 19 Inch
Quale preferite?
Engine
Compression: 8.2:1
Oil cooler.
Transmission
Gear ratios: 3.545
1st gear: 2.875
2nd gear: 1.773
3rd gear: 1.267
4th gear: 1.000
5th gear: 0.833
Reverse gear: 3.000
Performance
Body
Dimensions
Aerodynamics
Steering
Optional
Wheels
Tyres
Performance
Engine
Cylinders 12
Valves 48 valves.
Redline 7000
Gears 6
Transmission Manual
Dimensions
Seating Capacity 2
Doors 2
Exterior
Suspension
Brakes
Tires / Wheels
Quale preferite?
