Abarth Copuč a motore centrale
  • Abarth Copuč a motore centrale
    Abarth’s sports car line-up is growing! On top of the planned speedster and roadster version of the 500 exclusively revealed by Auto Express back in June (Issue 1,120), the Fiat-owned tuner has now confirmed it will build a Lotus Exige rival based on the radical KTM X-Bow.
    In a move that will delight fans of fast and focused Italian cars everywhere, senior sources within the company told us that the resulting model would be a
    limited-edition, mid-engined two-seater due in 2013.
    They’ve revealed that Abarth is buying a rolling chassis from the renowned Austrian motorbike maker, which ventured into the four-wheeler market for the first time two years ago. However, where the X-Bow had an Audi-sourced TFSI powerplant fitted behind the driver, Abarth will install a new 1.8-litre version of Fiat’s award-winning MultiAir turbocharged petrol engine, which will produce more than 200bhp.
    A unique bodyshell and interior will then be constructed around the X-Bow’s carbon fibre monocoque platform, swapping KTM’s chopped-up track car exterior for a more stylish appearance that references Abarth’s links with Fiat.
    As our illustration shows, the front end is likely to feature a bold grille and prominent badge in between oval lamps, similar to those on the 500. And even though the reskin will probably add more kilos to the X-Bow’s 790kg weight, it will make the car a much more practical proposition for owners.
    The likelihood is either a one-off production run of up to 2,000, or a limited-edition model with sales spread over two or three years. Prices are expected to range from around £42,000 to £50,000, giving the manufacturer a top-of-the-range model to sit above the more affordable hot hatches.
    Our insiders also confirmed Abarth had been in discussion with UK firm Lotus about using the Elise chassis and running gear for the car. But because it was relatively old technology – it dates back to the mid-Nineties – and comparatively expensive, bosses looked elsewhere. In addition, Abarth is planning to offer tuning services to other Fiat Group brands, although our source told us that this division could be under a new name.
    “Having Abarth and Cloverleaf makes no sense, but Alfa could resurrect the Autodelta badge,” he explained, referring to Alfa’s competition arm from 1961.
    Read more: http://www.autoexpress.co.uk/news/au...#ixzz0vefnz2PY
    in pratica telaio della x-bow, motore FPT 1.8 mAir, motore centrale, 2 posti, edizione limitata forse..
    precedentemente si stava discutendo di usare il telaio della Elise, ma č troppo "vecchio".
    forse verrą resuscitato Autodelta per elaborare le Alfa
    Auto Parts Nirvana
    Re: Abarth Copuč a motore centrale
    sogniamo troppo
    Originariamente inviato da IlVascoConLaGT
    noi veneti abbiamo l'obbligo di bere alla guida
    sull'auto metteremo un striscione con scritto : i vostri etilometri non fermeranno la nostra sete
      E' un Fake....
        Tempo fa era uscita la storia su quella basata sull'elise. Ovviamente come qualunque fiat che vada di fuori dell'ordinario... nn se ne farą nulla. Come l'Oltre e tante altre.
        Chi dice che una cosa non si puņ fare dovrebbe togliersi dai piedi di chi la sta facendo
        "Alla povertą mancano molte cose, all'avarizia tutte"
        (Publilio Siro)
          Il ps č fatto da autoweek, comunque sia tanto fake non č dato che ktm farą una versione della X-Box con parabrezza nel 2012.
          Auto Parts Nirvana
            Originariamente inviato da AJF Visualizza il messaggio
            come č scritto nella news c'erano stati dei contatti fra Fiat e Lotus, ma dato che il telaio della Elise č "vecchio" hanno preferito usare qualcosa di nuovo, aka telaio fatto da Dallara per la Ktm
            Auto Parts Nirvana
              la solita fiaba fiat...
              cmq č orrenda :S
              www.ripperz.it
                Originariamente inviato da Deynor Visualizza il messaggio
                Queste so le scuse, per non dire le ca**ate, per rimandare all'infinito... che diavolo significa vecchio... č un telaio fatto molto bene, in alluminio e senza saldature...
                (Publilio Siro)
                  Originariamente inviato da Ripperz Visualizza il messaggio
                  cmq č orrenda :S
                  č un ps di autoweek :|
                  č un telaio degli anni 90, IMHO se si vogliono fare le cose bene vą utilizzato qualcosa di nuovo
                  Auto Parts Nirvana
                    ok č un ps orrendo allora
                    www.ripperz.it
