Audi S3
  • Audi S3
    Tutte le informazioni le dritte i codici che vi servono per la vostra Audi S3........li potete trovare qui.
    Member of: CLUB NEW AUDI RS3
    --------------SOCIO FONDATORE------------
    >>>>>>>>>>>>>>La mia belva<<<<<<<<<<<<<
    Codici???
    http://www.casaportale.com/public/up...io_ditalia.pdf
    Spiacenti ---- č un moderatore/amministratore e non ti č consentito ignorarlo.
    ok, ma per ignorare solo al parte utonto ? quella che continua a scriver un mare di caxxate ?
      Messaggio originariamente postato da Nemis
      Codici???
      Codici dello stereo per entrare nelle informazioni della centralina, comunque li posto tra breve!
        Per tutti i possessori di S3 e TT
        Attenzione Codici (spiegazioni in inglese sorry) per entrare nelle informazioni delle Centraline Audi S3 e TT!!!!
        Note the following might vary slightly as this is from the A4, I have found it to be pretty close though.
        Changing Degree Temperature Display
        Press and hold the recirculation button. Then press the temperature up ("+") button to switch between degrees Celsius & Fahrenheit on the Climate Control Temperature and Instrument Panel Outside Temperature displays.
        Accessing On-Board Diagnostic codes
        Press and hold the recirculation button. Then press the manual flow control up arrow. You should see a 1c. Press the temperature up ("+") or down ("-") buttons to select a code number. Then press the recirculation button again. The value should display. Press the temperature up or down button again to display another code.
        NOTE: Air Flow Motor (V 71) and Potentiometer (G 113) are not installed in USA/Canada vehicles. Disregard values displayed for these components.
        Code Displayed Value
        1 System malfunction - displayed as a Diagnostic Trouble Code (DTC), see chart below
        2 Digital value of Interior Temperature Sensor, in Headliner (G 86)
        3 Digital value of Interior Temperature Sensor, in Instrument Panel (G 56)
        4 Digital value of Fresh Air Intake Duct Temperature Sensor (G 89)
        5 Digital value of Outside Air (Ambient) Temperature Sensor (G 17), front
        6 Digital value of Outside Air (Ambient) Temperature Sensor
        7 Digital value of Ambient Temperature Sensor At Fresh Air Blower (G 109)
        8 Digital value of Temperature Regulator Flap Motor Potentiometer (G 92)
        9 Delta value of Temperature Regulator Flap
        10 Non-corrected specified value of Temperature Regulator Flap
        11 Digital value of Central Flap Motor Potentiometer (G 112)
        12 Specified value of Central Flap
        13 Digital value of Footwell/Defroster Flap Motor Potentiometer (G 114)
        14 Specified value of Footwell/Defroster Flap
        15 Digital value of Air Flow Flap Motor Potentiometer (G 113)
        16 Specified value of Air Flow Flap
        17 Vehicle Speed (km/h)
        18 Actual Air Blower voltage (Volts)
        19 Specified Fresh Air Blower voltage (Volts)
        20 A/C Compressor (A/C Clutch) voltage (Volts)
        21 Number of low voltage occurrences, non-transient
        22 Cycle condition of A/C Refrigerant High Pressure Switch (F 118)
        23 Cyclings of the A/C Refrigerant High Pressure Switch (F 118)
        24 Cyclings of the switches, absolute non-fluctuating
        25 Analog/Digital value, Kick-Down Switch
        26 Analog/Digital value, Engine Coolant Temperature (ECT) Warning Light
        27 Coding value
        28 Engine Speed (RPM)
        29 A/C Compressor speed in rpm (Equals Engine Speed x 1.28)
        30 Software version
        31 Display check (all segments of A/C Control Head display light up)
        32 Potentiometer malfunction counter, Temperature Regulator Flap
        33 Potentiometer malfunction counter, Central Flap
        34 Potentiometer malfunction counter, Footwell/Defroster Flap
        35 Potentiometer malfunction counter, Air Flow Map
        36 Feedback value, cold end-stop, Temperature Regulator Flap Motor Potentiometer (G 92)
        37 Feedback value, hot end-stop, Temperature Regulator Flap Motor Potentiometer (G 92), max. stop
        38 Feedback value, cold end-stop, Central Flap Motor Potentiometer (G 112)
        39 Feedback value, hot end-stop, Central Flap Motor Potentiometer (G 112)
        40 Feedback value, cold end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
        41 Feedback value, hot end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
        42 Feedback value, cold end-stop, Air Flow Map Motor Potentiometer (G 113)
        43 Feedback value, hot end-stop, Air Flow Map Motor Potentiometer (G 113)
        44 Vehicle operation cycle counter
        45 Calculated interior temperature (internal software, in digits)
        46 Outside (ambient) temperature, filtered, for regulation (internal software)
        47 Outside (ambient) temperature, unfiltered, (internal software, in deg C)
        48 Outside (ambient) temperature, unfiltered, (in digits)
        49 Malfunction counter for speedometer (vehicle speed) signal
        50 Standing time (in minutes)
        51 Engine Coolant Temperature (ECT) in deg C
        52 Graphics channel 1 - A/C compressor switch-off conditions are identified by illuminated segments of the “88.8” display. See chart below.
        53 Graphics channel 2 - Climate system electrical outputs are identified by illuminated segments of the “88.8” display. See chart below.
        54 Control characteristics
        55 Outside (ambient) temperature, in deg C or deg F depending on setting on A/C control head
        56 Temperature in deg C, from Interior Temperature Sensor, in Headliner (G 86)
        57 Temperature in deg C, from Interior Temperature Sensor, in Instrument Panel (G 56)
        58 Temperature in deg C, from Fresh Air Intake Duct Temperature Sensor (G 89)
        59 Temperature in deg C, from Outside Air (Ambient) Temperature Sensor (G 17), front
        60 Temperature in deg C, from Ambient Temperature Sensor At Fresh Air Blower (G 109)
        61 Software version (latest)
        Gub’s S3
          Per tutti i possessori di Audi S3 e TT
          Seconda parte (messaggi di errore della centralina)
          Diagnostic Trouble Code Meanings
          Diagnostic Trouble
          Code (Sensor) Malfunction Description
          00.0 No malfunction present
          02.1 (G86) Interior Temperature Sensor, in Headliner, static open, *02.1 (see below)
          02.2 Interior Temperature Sensor, in Headliner, static short, see 02.1
          02.3 Interior Temperature Sensor, in Headliner, sporadic open
          02.4 Interior Temperature Sensor, in Headliner, sporadic short
          03.1 (G56) Interior Temperature Sensor, in Instrument Panel, static open, see 02.1
          03.2 Interior Temperature Sensor, in Instrument Panel, static short, see 02.1
          03.3 Interior Temperature Sensor, in Instrument Panel, sporadic open
          03.4 Interior Temperature Sensor, in Instrument Panel, sporadic short
          04.1 (G89) Fresh Air Intake Duct Temperature Sensor, static open, *04.1 (see below)
          04.2 Fresh Air Intake Duct Temperature Sensor, static short, see 04.1
          04.3 Fresh Air Intake Duct Temperature Sensor, sporadic open
          04.4 Fresh Air Intake Duct Temperature Sensor, sporadic short
          05.1 (G17) Outside Air (Ambient) Temperature Sensor, front, static open, *05.1 (see below)
          05.2 Outside Air (Ambient) Temperature Sensor, front, static short, see 05.1, *05.2 (see below)
          05.3 Outside Air (Ambient) Temperature Sensor, front, sporadic open
          05.4 Outside Air (Ambient) Temperature Sensor, front, sporadic short
          06.1 (G110) Engine Coolant Temperature (ECT), A/C static open, *06.1 (see below)
          06.2 Engine Coolant Temperature (ECT), A/C static short, see 06.1
          06.3 Engine Coolant Temperature (ECT), A/C sporadic open
          06.4 Engine Coolant Temperature (ECT), A/C sporadic short
          07.1 (G109) Ambient Temperature Sensor at Fresh Air Blower, static open, *07.1 (see below)
          07.2 Ambient Temperature Sensor at Fresh Air Blower, static short, see 07.1
          07.3 Ambient Temperature Sensor at Fresh Air Blower, sporadic open
          07.4 Ambient Temperature Sensor at Fresh Air Blower, sporadic short
          08.1 (G92) Temperature Regulator Flap Motor Potentiometer, static open, *08.1 (see below)
          08.2 Temperature Regulator Flap Motor Potentiometer, static short, see 08.1
          08.3 Temperature Regulator Flap Motor Potentiometer, sporadic open
          08.4 Temperature Regulator Flap Motor Potentiometer, sporadic short
          08.5 Temperature Regulator Flap, static block, *08.5 (see below)
          08.6 Temperature Regulator Flap Motor Potentiometer, malfunction
          08.7 Temperature Regulator Flap, sporadic block
          11.1 (G112) Central Flap Motor Potentiometer, static open, *11.1 (see below)
          11.2 Central Flap Motor Potentiometer, static short, see 11.1
          11.3 Central Flap Motor Potentiometer, sporadic open
          11.4 Central Flap Motor Potentiometer, sporadic short
          11.5 Central Flap, static block, *11.5 (see below)
          11.6 Central Flap Motor Potentiometer, malfunction
          11.7 Central Flap, sporadic block
          13.1 (G114) Footwell/Defroster Flap Motor Potentiometer, static open, *13.1 (see below)
          13.2 Footwell/Defroster Flap Motor Potentiometer, static short, see 13.1
          13.3 Footwell/Defroster Flap Motor Potentiometer, sporadic open
          13.4 Footwell/Defroster Flap Motor Potentiometer, sporadic short
          13.5 Footwell/Defroster Flap, static block, *13.5 (see below)
          13.6 Footwell/Defroster Flap Motor Potentiometer, malfunction
          13.7 Footwell/Defroster Flap, sporadic block
          15.1 (G113) Air Flow Flap Motor Potentiometer, static open, *15.1 (see below)
          15.2 Air Flow Flap Motor Potentiometer, static short, see 15.1
          15.3 Air Flow Flap Motor Potentiometer, sporadic open
          15.4 Air Flow Flap Motor Potentiometer, sporadic short
          15.5 Air Flow Flap, static block, see *15.5 (see below)
          15.6 Air Flow Flap Motor Potentiometer, malfunction
          15.7 Air Flow Flap, sporadic block
          17.0 Vehicle Speed Signal faulty
          18.1 Fresh air blower voltage, static
          18.3 Fresh air blower voltage, sporadic
          20.1 A/C compressor voltage not OK - static, *20.1 (see below)
          20.3 A/C compressor voltage not OK - sporadic
          22.1 (F118) A/C Refrigerant High Pressure Switch, static open, *22.1 (see below)
          22.3 A/C Refrigerant High Pressure Switch, sporadic open
          22.5 A/C Refrigerant High Pressure Switch, 120X open, *22.5 (see below)
          29.1 Belt slip detection "soft", static
          29.2 Belt slip detection "hard", static
          29.3 Belt slip detection "soft", sporadic
          29.4 Belt slip detection "hard", sporadic
          Diagnostic Trouble Code Notes: *02.1 Digital default value of 128 is programmed if sensor fails
          *04.1 Value supplied by Temp. Sensor is used if sensor fails
          *05.1 Value supplied by Temp. Sensor is used if sensor fails
          *05.2 Digital default value of 128 is programmed if sensors G89 & G17 both fail
          *06.1 Engine Coolant Temperature is calculated is sensor should fail or is not installed; diagnosis occurs only above 0 degrees Celsius
          *07.1 Programmed corrective value = 0
          *08.1 Temperature Regulator Flap Motor will no longer be controlled automatically; manual adjustment only
          *08.5 Motor is cycled; software attempts to eliminate block
          *11.1 Central Flap Motor will no longer be controlled automatically; manual adjustment only
          *11.5 Motor is cycled; software attempts to eliminate block
          *13.1 Footwell/Defroster Flap Motor will no longer be controlled automatically; manual adjustment only
          *13.5 Motor is cycled; software attempts to eliminate block
          *15.1 Digital value is internally programmed for limp-home mode
          *15.5 Motor is cycled; software attempts to eliminate block
          *20.1 Compressor remains off until voltage is greater than 10.8V for at least 25 seconds
          *22.1 Compressor remains off until switch closes
          *22.5 Compressor re-engagement circuit, VAG 1551 Scan Tool function
          OBD Channel 52 - A/C Compressor switch-off codes
          If an A/C compressor switch-off condition exists, a segment of the "88.8" display, indicated below as an alpha-numeric code, will illuminate.
          Segment Condition
          a1 Slippage or blockage, A/C Refrigerant High Pressure Switch, 120x off
          b1 Engine Speed (RPM) less than 200 - 500
          c1 Engine Speed (RPM) greater than 6000
          d1 Engine Speed (RPM) greater than 6000
          e1 System function OK
          f1 System function OK
          a2 A/C manually switched off (A/C standby canceled)
          b2 low voltage
          c2 Kick-down switch, compressor off for 12secs max.
          d2 Engine Coolant Temperature (ECT) warning light switched
          e2 A/C Refrigerant Low Pressure Switch (F73)
          f2 A/C Refrigerant High Pressure Switch (F118)
          a3 ECON mode selected
          b3 OFF selected
          c3 Outside (ambient) temperature too low
          d3 Engine management system (compressor will remain off for 3 -12 seconds)
          e3 High pressure occurrences more than 30 times
          f3 Ambient Temperature Sensor at Fresh Air Blower (G109) less than 27 degF (-3 degC)
          g1,g2,g3 System function OK (g1+g2+g3 must illuminate simultaneously to indicate system is OK)
          Decimal Point
          Lit A/C compressor ON
          Decimal Point
          Unlit A/C compressor OFF
          OBD Channel 53 - Climate system electrical output codes
          When a NO system electrical output is activated, a segment of the "88.8" display, indicated below as an alpha-numeric code, will illuminate. The decimal point in the "88.8" display will not illuminate in this channel.
          Segment Condition
          a1 Fan for interior temperature sensor
          b1 Fresh air/recirculation flap closed (recirculation mode)
          c1 Heater valve closed
          d1 Bi-directional wiring harness
          e1 A/C compressor ON
          f1 coolant fan first speed ON
          a2 Air flow flap open
          b2 Air flow flap open
          c2 Air flow flap closed
          d2 Footwell/Defroster flap in "Footwell" position
          e2 Footwell/Defroster flap in "Footwell" position
          f2 Footwell/Defroster flap in "Defroster" position
          a3 Central flap in "instrument panel outlet" position
          b3 Central flap in "instrument panel outlet" position
          c3 Central flap in "footwell outlet/defrost" position
          d3 Temperature flap in "cold air" position
          e3 Temperature flap in "cold air" position
          f3 Temperature flap in "warm air" position
          Gub’s S3
            A tutti i possessori di Audi S3 e TT
            Opzioni per entrare nel menu funzioni addizionali dei vostri stereo, COncert o Sinfony (mod 2001, ma provare anche modelli precedenti!):
            (solo inglese)
            The information contained within this FAQ may not be applicable to all car
            models. The author has
            found this information to be correct for an Audi A3 MY2001, fitted with standard
            equipment
            consisting of a Concert head unit, 6 CD stacker, 4 x 20W speakers plus 40W
            subwoofer. This
            information is assumed to be applicable to any vehicle fitted with the Concert
            head unit, with or
            without the BOSE sound system upgrade. The author takes no responsibility for
            any injury, damage
            or loss sustained from usage of information contained herein.
            Audi Concert Sound System - Additional Functions
            - These are accessed by holding down the TP button when switching on the sound
            system. The TP
            button is then used to cycle through available functions, and adjustments are
            then made with the
            volume knob.
            TA – Traffic Announcements volume.
            1 = lowest volume
            5 = highest volume.
            GALA – Speed-dependent volume control. This will slightly increase the
            volume of the sound
            system as the speed of your vehicle increases, for the purposes of compensating
            for engine and
            road noise.
            0 = disabled
            1 = least effect
            5 = most effect
            VOL – Limits pre-set volume when system is switched on.
            1 = lowest volume
            5 = highest volume
            SENS – Radio station search sensitivity. DX, distance reception, means
            the radio will stop
            at stations with weak signals, while LO, local, will cause the radio to only
            stop at stations with
            strong signals.
            RM – Radio monitoring. When switched on, the system will switch to radio
            when fast
            forwarding or rewinding a cassette.
            NAV – reduction of radio volume level when receiving navigation
            instructions.
            1 = least reduction of radio volume, meaning navigation instructions sound
            quieter
            5 = most reduction, resulting in louder-sounding navigation instructions
            TEL – toggling of hands-free loudspeaker for in-car mobile telephone,
            between left (L) or
            right (R).
            - Hold down these numerical buttons while switching on the sound system for
            these functions:
            1 – gives a digital value for the current radio station, system operation is
            otherwise unaffected.
            2 – returns the current level by which GALA (speed-dependent volume control) has
            increased the
            system volume. If GALA is disabled, ‘GALA OFF’ will be displayed. System
            operation is otherwise
            unaffected.
            3 – returns the firmware version of the sound system, system cannot be operated.
            Other functions and information
            The Traffic Announcements function (TP) is disabled by holding down the TP
            button.
            For systems equipped with the Symphony head unit and BOSE sound system ONLY:
            Holding down '5' when switching on the system accesses the equaliser, which is
            represented by a
            row of 8 digits. These represent, from left to right:
            -Low frequency, front speakers
            -Low-middle frequency, front speakers
            -Middle-high frequency, front speakers
            -High frequency, front speakers
            -Low frequency, rear speakers
            -Low-middle frequency, rear speakers
            -Middle-high frequency, rear speakers
            -High frequency, rear speakers
            Use the volume knob to adjust the values, and the TP button to cycle between the
            setting to
            adjust. The system must be turned off then on for adjustments to take effect.
            Gub's S3
              percaso hai un codice per sapere il codice(numero di serie delle centralina s3?
                Messaggio originariamente postato da kekko
                No purtroppo, questi sono gli unici che conosco.
                  r
                  figo......
                    Io ho un A3 e questi funzionano per tutte le audi con clima automatico. Non solo per S3 e TT
