Vendo per conto di un amico l'ampli in oggetto.
AUDIO SYSTEM TWISTER F2 450
E' un vero mostriciattolo, guardate le caratteristiche:
Audio amplifier system Twister F2-450 (2 Ch)
2-channel amplifier
Color: white
Height: 48cm x 21 cm x 5 cm
Active cooling
All services (electricity, RCA, speakers) on one side
Seperater connection for capacitor (PowerCap)
Performance according to the manufacturer:
2 x 225 watts RMS at 4 ohms Stereo
2 x 350 watts RMS at 2 ohms Stereo
1 x 450 watts RMS at 8 ohms Mono
1 x 700 watts RMS at 4 ohms Mono
(WHICH MAKES YOU ALSO!)
Signal-to-noise ratio: 102 (105 dB)
Damping factor of 4 Ohm/1khz:> 250
Input Impedance:> 11 kOhm
Working voltage: 10,5-16 Volt
Weekly Electricity: 1.3 ampere
Maximum current consumption: 50 amps
High Pass or LowPass of 45-450 Hz
Weight: approximately 3.6 kg
Price 380.00 €
VERAMENTE NUOVO!!!!! SEMBRA APPENA USCITO DAL NEGOZIO!
Lo vendo per 160 euro tratt.
Anche su Ebay: http://cgi.ebay.it/ws/eBayISAPI.dll?...MESE:IT&ih=003
INOLTRE VENDO ANCHE:
Rockford Fosgate Punch 200ix 2x150WRMS 1x500WRMS
Buono stato, FUNZIONA BENISSIMO! Veramente un ottimo ampli di gran qualità.
Ecco alcune caratteristiche della casa:
Rockford Fosgate PUNCH 200ix
Dynamic Power Rating (IHF-202 Standard) - Measured at 14.4 Volts
Mono into a 4Ω Load 500 Watts
Per channel into a 2Ω Load 240 Watts
Per channel into a 4Ω Load 150 Watts
Continuous Power Rating (Competition Standard) - Measured at 12.6 Battery Volts
RMS continuous power per channel,
both channels driven into a 4Ω load 100 Watts
from 20 to 20,000 Hz with less than
0.05% Total Harmonic Distortion (THD)
both channels driven into a 2Ω load 200 Watts
from 20 to 20,000 Hz, with less than
0.1% Total Harmonic Distortion (THD)
RMS continuous power mono into a
4Ω load from 20 to 20,000 Hz, with 400 Watts
less than 0.1% Total Harmonic
Distortion (THD)
Signal-to-Noise Ratio > 100dB A-weighted
Ecco il manuale della casa con altre caratteristiche: http://www.rockfordfosgate.com/rftec...x200ix_MAN.pdf
Ecco un altro sito molto utile con i watt rilevati su banco prova e non quelli dichiarati dalla casa: http://www.mopz.de/carhifi/rflist.htm
Unica pecca dell'ampli è che il vecchio proprietario aveva spanato la morsettiera di alimentazione, quindi con la filiera ho rifatto la sedte e quindi le viti non sono quelle originali, IL RESTO E' OK.
PREZZO 190€
Valuto anche offerte. Valuto permute con PG ZX 600 o Steg K24 + mio eventuale conguaglio.
2-channel amplifier
Color: white
Active cooling
Price 380.00 €
Distortion (THD)
PREZZO 190€
