Re: GTR2
l'ho postato pochissime pagine fa.
; -------------------------------------------------------------------- ; GTR2-XD v1.0.2 ;-------------------------------------------------------------------- ; by (ASD)Yako (yako@vitumo.de) ; www.vitumo.de ; -------------------------------------------------------------------- ; 1 = Enabled (default), 0 = Disabled Enabled=1 ; 0 = Show all Info in one small overlay window (Use on/off key to cycle through views) ; 1 = Set to 1 if you are using the original GTR-HUD (default) ; 2 = Use this if you are not going to use the GTR-HUD Mode=0 ; 0 = No transparency at all ; 1 = Semi transparent HUD (default) ; 2 = Full transparent Transparency=1 ; MotecHud visibility ; 0 = Hidden ; 1 = Visible ShowMotec=1 ; Standings-table visibility ; 0 = Hidden ; 1 = Visible ShowStandings=1 ; SessionInfo visibility ; 0 = Hidden ; 1 = Visible ShowSessionInfo=1 ; MoTeC HUD postion: ; Default x=8; y=8 MotecPosX=8 MotecPosY=480 ; Standings HUD postion: ; Default X=auto; Y=auto StandingsPosX=auto StandingsPosY=auto ; Session-info HUD postion: ; Default x=auto; y=auto SessionPosX=auto SessionPosY=auto ; 0 = Times are displayed according to leader (default) ; 1 = ... or to yourself StandingsMode=0 ; 0 = Disable AutoScroll feature, use up/down keys to scroll through the field ; 1 = Activate AutoScroll, player will always be in the middle of the table (default) StandingsAutoScroll=1 ; 0 = Imperial ; 1 = Metric (default) MeasurementUnits=1 ; Refresh rate (in ms) default: 250 RefreshRate=250 ; MoTeC HUD Scale ; Note: Only the MoTeC-Display can manually be scaled. ; Everything else is scaled automatically according to your screen resolution ; If the MoTeC display is set to tab-mode, the other info is also scaled (Session Info/Standings) ; Value given in percentage ; 100(%) Scale = 1024x768 = 1:1 = No Transformation ; 0 = Disable scaling Scale=80 ; Key to switch on/off ; Possible keyboard layouts: ; For DE: http://www.vitumo.de/files/GTR2XD/keyStroke.de.txt ; For EN: http://www.vitumo.de/files/GTR2XD/keyStroke.en.txt ; Default: 220 = Circumflex Symbol (Next to the '1' key on main-field) ; For English Keyboard layout please insert 192 here (the '`' key), or the key is mapped to the backslash-key ToggleKey=220 ; Show tyre pressure ; 0=Disabled ; 1=Enabled (default) TyrePressure=1 ; Show tyre wear also in numbers ; 0=Disabled ; 1=Enabled (default) ShowTyreWearInNumbers=1
[B]; 0 = Show all Info in one small overlay window (Use on/off key to cycle through views)[/B] ; 1 = Set to 1 if you are using the original GTR-HUD (default) ; 2 = Use this if you are not going to use the GTR-HUD Mode=0
; MoTeC HUD postion: ; Default x=8; y=8 MotecPosX=8 [B]MotecPosY=480[/B]
; MoTeC HUD Scale ; Note: Only the MoTeC-Display can manually be scaled. ; Everything else is scaled automatically according to your screen resolution ; If the MoTeC display is set to tab-mode, the other info is also scaled (Session Info/Standings) ; Value given in percentage ; 100(%) Scale = 1024x768 = 1:1 = No Transformation ; 0 = Disable scaling [B]Scale=80[/B]
