Specifiche Tecniche:
engine Inline-8 w/Cast Iron Block, Dry Sump Lubrication
position Front Longitudinal
aspiration Supercharged
valvetrain 2 Valves per Cyl, DOHC
fuel feed Stromberg UUR-2 Carburetor
displacement 3257 cc / 198.8 cu in
bore 72 mm / 2.83 in
stroke 100 mm / 3.94 in
compression 8.5:1
power 156.6 kw / 210 bhp @ 5500 rpm
hp per litre 64.48 bhp per litre
bhp/weight 220.36 bhp per weight
redline 5500
drive wheels RWD
body / frame Aluminum over Ash Wooden Supports over Steel Frame
front brakes Drums
f brake size 381 mm / 15 in
rear brakes Drums
r brake size 381 mm / 15 in
front wheels F 45.7 x 14.0 cm / 18 x 5.5 in
rear wheels R 45.7 x 16.5 cm / 18 x 6.5 in
front tire size Dunlop
rear tire size Dunlop
steering Worm & Roller
f suspension Semi-Indpenedant Centrally Collared Axles w/de Ram Shock Absorbers, Leaf Springs
r suspension Solid Axle w/de Ram Shock Absorbers, Quarter-EllipticLeaf Springs
weight 953 kg / 2101 lbs
wheelbase 2979 mm / 117.3 in
front track 1349 mm / 53.1 in
rear track 1349 mm / 53.1 in
transmission 4-Speed Manual
top speed 200 kph / 124.3 mph
0 - 60 mph 10 seconds
production 3
designers Jean Bugatti, Joseph Walter
Una delle auto più ancora oggi secondo me
Non trovate?
compression 8.5:1
redline 5500
drive wheels RWD
front brakes Drums
rear brakes Drums
production 3
Non trovate?
