Come da titolo...ampli presi, provati e messi via per abbandono momentaneo car audio..quindi come nuovi, nemmeno avvitati..15 min di utilizzo..
Li dò per 260 euro l'uno oppure 510 spediti entrambi..ùecco le specifiche tecniche...ho tutte le foto che volete...
KILLER LINE KA.1700D
AMPLIFICATORE MONOCALE - 2800 WATTS MAX
Digital class-D linkable mono amplifier
MOSFET PWM Power Supply
Daisy-chain through output RCA
Double sided through hole epoxy PCB
Stable into 1 ohm and 2 ohm parallel amplifier connection availability
24dB/oct variable crossover
Variable subsonic filter > Variable bass boost
Variable low pass filter
Efficiency: 86% @ 4 ohm, at 100Hz
Multy-way protection circuitry (Thermal/over Current/speaker short / speaker DC protection)
RCA line input
Tested voltage THD: 14.4V & less than 1% THD
Operating voltage: DC10V~15.5V Power Input
Wired remote controller (optional)
Rated power output:
RMS power, 2 ohm linkable dual mono........ 4100W x 1CH
RMS power, 1 ohm mono........................ 2100W x 1 CH
RMS power, 2 ohm mono........................ 1350W x 1 CH
RMS power, 4 ohm mono........................ 700W x 1 CH
Signal to Noise Ratio.................................. >98dB
Low Pass Crossover................................... 30Hz~300Hz
Subsonic Filter......................................... 10Hz~60Hz
Bass boost @ 45Hz..................................... 0~18dB
Phase shift control.................................... 0~180 degree
Frequency response................................... 10Hz~350Hz (+/- 1dB)
THD @ RMS Watts..................................... <1.0%
Efficiency @ 4 ohm................................... 86%
Fuse rating............................................. 40A x 3
Input sensitivity....................................... 200mV~6V (+/- 5%)
Dimensions............................................. 260(W) x 54.5(H) x 360(L) mm
RCA line input
Rated power output:
