Texaco Havoline Ultra 5w40
  • Texaco Havoline Ultra 5w40
    Ho trovato questo olio interamente sintetico (cosi' c'e' scritto sul sito)
    a 7-7,5 Euro al Lt , volevo sapere se era buono come un olio
    Mobil o un Castrol
    Vorrei usarlo nella mia Mercedes al prox cambio
    Attualmente uso il Mobil 1 5W50.
    Vorrei passare a questo anche perche' e' un longlife e siccome Mercedes effettua il cambio ogni 20000 km vorrei stare piu' tranquillo.
    Inoltre mi costerebbe di meno del Mobil 1
    Ecco il link alle sue caratteristiche
    http://www.uztexaco.com/cgi-bin/page...ime=1120725865
    Le riassumo anche qui:
    Description
    Havoline Ultra 5W-40 – fully synthetic premium quality engine oil for modern passenger cars and light-duty trucks with most demanding engine performances.
    Benefits
    It has excellent low-temperature performance during start-up.
    It gives wear, corrosion, deposits and slag protection to the engine, keeps it clean for a long period.
    Guarantees stable viscosity in the most severe performance conditions.
    Reduces exhaust emissions and has long-life performance, thus reducing maintenance time and costs.
    Application
    Havoline Ultra 5W-40 can be used in both petrol and diesel fueled cars in all climate conditions, for engines with turbo charge or without it, injector sprinkled fuel and multi valve system, where engine manufacturer recommends performance levels on API SJ/SF and ACEA A3-98/B3-98.
    The oils are also recommended for engines where low performance levels are prescribed like API and ACEA (SF, SG, SH, A2-96), and for engines with gas facilities.
    Certificates & approvals
    API SL/CF; ACEA A3-04/B4-04;
    Porsche; BMW Longlife Oil-98; VW 502.00/505.00;
    Opel/GM-LL-B-025; MercedesBenz 229.3
    Typical data
    1 Density at 15°С, kg/l 0.856
    2 Kinematic viscosity at 40°С, mm2/s 85
    3 Kinematic viscosity at 100°С, mm2/s 14.4
    4 Viscosity index 177
    5 Pour point, °С -42
    6 Flash point, °С 224
    Quelli dell'OdC®...
    Re: Texaco Havoline Ultra 5w40
    interessante, sembra buono
    dovrebbe essere in qualche modo un marchio connesso con la VALVOline
    mi dici dove lo hai trovato ?
      da mio fratello
      ha un negozio tipo Brico ed ha olii texaco, semisintetici 15W40 e 10W40 e sintetici solamente il 5W40 Havoline Ultra
      se avesse avuto anche un 0W40 (non so neanche se la texaco lo ha) lo avrei preso al volo per il tagliando che ho fatto da 5000 km
      purtroppo allora aveva solo i semisintetici
      comunque quello e' il prezzo che lui li paga, quindi al pubblico sarebbe piu' alto
      credo che i lubrificanti siano in comune tra Texaco, Chevron e Caltex, perlomeno il sito le indica tutte e tre
      volevo solo sapere se potevo azzardare la sostituzione del mio Mobil 1 5W50 con questo 5W40 (secondo me piu' consono al mio motore), anche se il Mobil e' un olio eccezionale
      mav_top
      Quelli dell'OdC®...
        ecco le caratteristiche del Mobil 5W50
        Typical Properties Mobil 1 15W-50:
        SAE Grade 5W-50
        Viscosity, ASTM D 445
        cSt @ 40ºC 105
        cSt @ 100ºC 17.3
        Viscosity Index, ASTM D 2270 153
        Sulfated Ash, wt%, ASTM D 874 1.2
        HTHS Viscosity, mPa-s @ 150ºC ASTM D 4683 4.22
        Pour Point, ºC, ASTM D 97 -51
        Flash Point, ºC, ASTM D 92 236
        Density @15 ºC kg/l, ASTM D 4052 0.859
        Quelli dell'OdC®...
          io penso di si,sopratutto ora che è freddo e ancora piu se abiti al nord
          la prova la farei (ammesso che tu debba comunque cambiare l'olio)
          sembra un olio dalle buone caratteristiche
          in che citta sta tuo fratello ?
          Ultima modifica di Inox; 19-12-2006, 13:52.
            vicino roma ai castelli romani
            Quelli dell'OdC®...
              io pensavo che se fosse della stessa qualita' del mobil, potrei tenerlo anche d'estate tanto la mia dieselina non la sforzo troppo
              Quelli dell'OdC®...
                Originariamente inviato da mav_top Visualizza il messaggio
                le caratteristiche del " nuovo " olio sono ottime.
                credo tu possa provare senza remore.
                anche se io, come sai... dal Mobil 1... non mi staccherei
                ciauzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
                  lo so lo so che sei mobil dipendente
                  ma mentre il mobil lo pago 10-11.5 a lt questo mi costerebbe 7-7.5
                  inoltre si avvicinerebbe meglio a quello previsto dalla casa
                  e sarebbe pure un LongLife
                  tre cose migliori dell'attuale e prezzo inferiore
                  certo il mobil e' mobil, non conosco il pacchetto additivi, comunque
                  penso sia valido pure questo
                  vedremo al prox cambio se il motore lo consuma e quanto
                  mav_top
                  Quelli dell'OdC®...
                    io lo usavo fino pochi anni fa: è il peggior 5w40 mai provato (anche se sulla carta figurava ottimo).
                    Club punto 75
                    Quelli della Punto 85
                    Club F.I.R.E. 45
