Amplificatore Alpine
  • Amplificatore Alpine
    ciao raga, stò per comprare questo amplificatore: Alpine MRP-F450
    al modico prezzo di 300€, il mio soundstream mi ha un pò stancato e volevo cambiarlo.
    ecco i dati tecnici. Voi cosa ne pensate? è un buon sostituto al mio soundstream XTA 480.4?
    Features
    4/3/2 Channel Operation
    High Temperature Protection
    Overcurrent Protection
    Subsonic Filter
    Bass EQ Circuit
    Adjustable Crossover (HP/LP)
    MOSFET Power Supply
    DC-DC PWM Power Supply
    Discrete Pre-Amp Stage
    STAR Circuitry
    Auto Over-Current Protection
    MultiModeª
    Top Mounted Blue LED Power/Status Indicator
    Input Channel Selector
    Gold Plated RCA Input Connectors
    Continuously Adjustable Gain Control
    Speaker Level Inputs
    Gold Plated Power Screw Terminals
    Gold Plated Speaker Terminals
    4-Layer Glass Epoxy PC Board
    CEA-2006 Power Rating
    CEA-2006 Power Rating (40hm at 14.4V = 1%THD+N), S/N 80dBA (Ref. 1W into 4Ohm): 70W x 4
    RMS Power (at 14.4V THD+N, 20Hz-20kHz)
    Per channel into 4 ohms: 70W x 4 (0.08% THD)
    Per channel into 2 ohms: 140W x 4
    Brigded 4 ohms: 350W x 2 (0.3% THD)
    Bass Engine® Sound Tuning
    Crossover Frequency : 50Hz - 400Hz HP/LP/Off(-12dB/oct)
    Subsonic Filter (Fixed): 15Hz
    Bass EQ Frequency (Fixed): 50Hz +12dB (Ch3/4) On/Off
    Dimensions
    Heat Sink (WxHxD) in: 11-15/64" x 9-31/64" x 2-23/64"
    Heat Sink (WxHxD) mm: 285mm x 241mm x 60mm
    Foot Print (WxHxD) in: 13" x 9-31/64" x 2-23/64"
    Foot Print (WxHxD) mm: 332mm x 241mm x 60mm
    General
    Power Requirements: 14.4V DC (11V to 16V)
    Fuse Type: 30A x 2
    Frequency Response: 10Hz - 50kHz (+0,-1dB)
    Signal to Noise (S/N): 100dBA (Reference to Rated Power)
    Input Sensitivity (For Rated Power): 0.2V to 4.0V (1.0 at Center Detent)
    Input Impedance: 10k Ohm
    Speaker Impedance: 4 or 2 ohm Bridged
    Weight: 3.3 Kg.
    Re: Amplificatore Alpine
    suonano bene sti alpine...
    sicuramente meglio del tuo soundstream
    hanno molta potenza però sono abbastanza controllati nulla a che vedere con le serie made in japan però..
      io andrei su steg........
      Il mio impiantino:-
      Sorgente:...............Kenwood KDC-W7534U-Tweeter:.................Kicker nd25-Woofer:..................tec sq6-Crossover:.............Hertz hi energy 2w.20/probabile sostituzione SubWoofer:............Kicker solo baric L5 8'(cassa da 22 l + 5,3l di porta) / SubWoofer invernale solo baric s8c(cassa da 9,3 litri)-Amplificatore FA+sub: MTX Thunder5400X 5 chann 2x100w 4 ohm mono sul front piu il sub 200w su 2 ohm-condensatore da 1 farad-portiere insonorizzate
      La mia tavola da snowboard
      1: Burton Supermodel x 164 2007/2008 (freeride) 2: F2 Wideglide 2004(da usare con pietre ecc ecc da sfascio!!!)
        steg no grazie. voglio fare tutto l'impianto firmato alpine. ho anche comprato il subwoofer SWD-3000.
          diegt130 perchè dici che và meglio del soundstream?
            io lo ho e va benissimo ottiam riserva di potenza e controllo soprattutto se la radio ha i pre a 4volts, soprettutto meglio dei soundstream detto da te, sentiti entrambi su imianti simili
            ho notato un cambiamento colossale passando dalla 9853 alla 9887
            per il prezzo non so ho trovato un occasione su e-bay di uno a cui avevano fatto un regalo doppio e l'ho preso a 230€, sul nuovo però non saprei dirti
            Club Alfa Italia
              mister84 perchè mi dici che l'amplificatore è ottimo con radio che ha le pre a 4volts? che tralantro io ho perchè la mia radio è una alpine 9812rb.
              io lo stò pagando 289€ su rebelio. e 289€ il subwoofer swd-3000
                ampli arrivato. lo provo e poi vi sò dire. mister84 aspetto una delucidazione da te sul fatto dei 4volts.
                  Originariamente inviato da kekko nos Visualizza il messaggio
                  io avevo la 9853r e i pre erano a 2 volts.
                  quando settimana scorsa ho messo la 9887r che li ha a 4 ho dovuto praticamente dimezzare i gain adesso risco ad arrivare più sù col volume manetenendo nitidezza nel suono
                  Club Alfa Italia
                    suona che è una favola....sono molto contento di questo acquisto. con la 9812rb prima arrivavo a 25 di volume col soundstream e già iniziava a distorgere leggermente......con questo alpine arrivo al massimo e non distorge di niente. favoloso.
